Anyone managed to get Cyan?
bshadown
Re: Anyone managed to get Cyan?
Post by bshadown »
My Cyan cart is also not 100% clicked into placed like the others, it pops out a little but am getting ink come through
ok im New to all of this but i can absolutly tell you! your problem is not comin from the software, it might be the cartriche not conected properly or it might be damage, anyway try using a diferent printer or sending yours to service! it might help. Cheers
Ps: if you see estrange words, Its my iPad auto-correcction cant turn it off.
liannef
Post by liannef »
Hi
Still haven't solved this yet but Sawgrass stopped replying to my emails and TMT blamed the powerdriver but were helpful and gave me another ICC Profile to try but that was even worse than the Sawgrass one so getting Paul to create me one but he's on holiday at the moment so hopefully this will fix my problems. I've pushed the Cyan cart in and held it in place with tape and noticed no difference so will see what a new Profile does, will keep you posted.
Lianne
liannef
Post by liannef »
I notice that Sawgrass have a v1.03 for there ICC profile so downloaded that and noticed no difference to the v.01 that I have. I have had a custom ICC profile made, I pressed the charts onto a t-shirt and they did it from that and it is almost identical to the sawgrass profile but the cyan is a pale blue and the green is light instead of dark, both don't produce a magenta but the neon red is the next best. I think I'm still going to get Paul to do a profile next week though when he's back off holiday but not holding out much hope. Think I'm going to have to print out the Sawgrass palette and use that in CorelDraw and hope I don't get any logos etc where I can't tweak the colours!
bshadown
Post by bshadown »
I just did a couple of test on poliéster yesterday, Was having is isues with colors as well, what i did was (in Photoshop) use adobe 1998 as my working icc, then when printing i Check "Photoshop manage the colors" and choose sRGB as my printing icc also dont forget to turn off your printers color management, and thats all worked fine for me, the isues Came from the timing on the heat bed, the guy who sold me everything gave said i need 180 C @ 80s, didnt work, i had to raise it to 180s. Give it a try and tell us what happends
sRGB is another working space profile like Adobe 1998, it is NOT a printer profile, this in Photoshop is where you need to select the ICC profile from your ink manufacturer, or the ICC profile you've had made, or made yourself if you have the kit, or at the very worst an ICC for another manufacturers sublimation ink.
bshadown
Post by bshadown »
yes i wish i had all of the above pisquee, but the guy who sold me the printer and the heat press didnt give me any icc, plus the time and temperature for everything is wrong, i already got like 10 plates lying around becuase the color was burn out or the image is fading. ie: poliester T-shirts it saids 180 C @ 80s buuuttt...... it would work only at 180 C @ 180s, mugs 200 C @ 200s the same dosent work and plates, is the same stuff. just sharing a little of my pain lol,
What printer do you have, and what sublimation ink?
bshadown
Post by bshadown »
Epson L110 with inkwo inks(chinesse) adobe 1998 for my working icc in Photoshop and sRGB for printing(Photoshop handles the colors),
according to the instrucción manual the guy gave me mugs sublimate at 200C @ 200s, dosent works, i manage to make it work at 180C @ 150s a little bit dark but i guess is the sRGB icc
bshadown;91094 wrote:Epson L110 with inkwo inks(chinesse) adobe 1998 for my working icc in Photoshop and sRGB for printing(Photoshop handles the colors),
Hi there,you need to read what piquee said couple posts up. sRGB is not a printing icc. Its working space that photoshop use. so you probably will be better off to not use any at all. but this won't sort your problems out aim afraid :(
can you tell us more about your blanks? t-shirts, mugs and plates? where you got them from?are you sure they are suitable for the job?
regards
bshadown
Post by bshadown »
cant tell the brand of the press, they guy who sold me everything was starting, i was his first customer and he sold me the press, cap and mug atachedment, from what i can tell it was a chinnese one, i used to have a t-50 printer with ciss but the ink stop flowing and i simply leave it there for at least 8 monts, its acctually now that im starting to check everything again, thats why i bought the l110 with the CISS. i will post some pictures of the equipment i have meabe you guys can help me out. by the way, should i start a new post or continue on this one?? thanks
Users browsing this forum: Bing [Bot] and 10 guests
