Is there an easy file sharing solution or an add on to Opencart from one of these services that could make this easier? Bearing in mind the folk uploading have very little computer knowledge.
Opencart Max filesize upload
Re: Opencart Max filesize upload
So a customer just tried to upload a 22Mb photo to me for an order
She's ended up having to email across a standard connection. I suggested Dropbox but she'd never heard of it, lol.
- WePrintForYou
We have a 50mb file upload limit, you might need to check with your hosting provider your php.ini settings or use a htaccess workaround to try to achieve a higher upload limit.
Large Format, Sublimation, Direct To Garment Wholesale Manufacturer. No Minimums
You could consider HIGHTAIL, its the one I use all the time for receiving and sending files. They have a free version and a paid one with differences to each.
Yes, I could increase the limit, just wondering if this is the best upload method,want it to be as straight forward as possible for customer.....will check out suggestions, many thanks.
media fire offer "filedrop" file is uploaded normal way via website upload button. i think single file size limit is 2GB and all files go straight to your hosting. maybe worth a look.
I found a link to the site Paul, uploaded a large file and it said do I want to upload anything else? No links or anything thoughPaul;91146 wrote:media fire offer "filedrop" file is uploaded normal way via website upload button. i think single file size limit is 2GB and all files go straight to your hosting. maybe worth a look.
Over-thinking this a little maybe as most images will be smaller but kinda just playing devils advocate!
edit: Just re-read you post Paul and noticed you mention the upload button, doh! I see what you're saying now, sorry.
