not exactly over the moon
twinsgran
Re: not exactly over the moon
Post by twinsgran »
Re: The precut sheets. I bought some of these but they are a tad too big for my keyrings so I still had to cut them down! The inserts came from Intaprint and the keyrings from a supplier on ebay but 50mmx35mm keyrings should be the same where ever they come from. Now I'm getting frustrated. It's not as if there's much profit coming from these, considering the time they are taking me to get them right. :(
grobbo
Post by grobbo »
Hi spongerobinson. I eventually had 2 boxes of the c1 delivered but they all had the same issues with slight airline cracks in the viewing window. I asked to be sent the c6 keyrings but a box of c1 were delivered again with same faults. 4th time they sent c6 which have been a lot better. They still not hundred percent right but acceptable. Intaprint have been great in all fairness but I will definitely be trying somewhere else next time. Ebay so far has been my best supplier for quality suprisingly.
spongerobinson;91713 wrote:Did you ever get these problems sorted grobbo? Thinking of getting some keyrings in to try.
grobbo
Post by grobbo »
Hi twinsgran, i have had the issue a while back where the keyrings were actually about 51mm x 36mm so when i was printing a image to 50mm x 35mm they were to small in the keyring. Intaprints keyrings are bang on 50mmx35mm so obviously depending on supplier will depend on actual size.
twinsgran;91716 wrote:Re: The precut sheets. I bought some of these but they are a tad too big for my keyrings so I still had to cut them down! The inserts came from Intaprint and the keyrings from a supplier on ebay but 50mmx35mm keyrings should be the same where ever they come from. Now I'm getting frustrated. It's not as if there's much profit coming from these, considering the time they are taking me to get them right. :(
spongerobinson
Post by spongerobinson »
thanks grobbo...might try find a reliable ebay supplier so!
Andrew
Post by Andrew »
These mostly come from the same source when buying off UK suppliers as there is a major importer used. Intaprint is as good as any and costs are decent so I would think it just a one off batch. They would be my choice.
