Silhouette Cameo
tiamaria
Re: Silhouette Cameo
Post by tiamaria »
im getting rid of my roland camm 1 cx24 as i cant find software or get it set up with my windows 7 pc as i cant download drivers for it ,can only find drivers for win xp or vista , so my next question is does anyone know of anywhere local to me (cardiff area) where i can go and buy a Silhouette Cameo v2 many thanks justin
WePrintForYou
Post by WePrintForYou »
You could use VMware to run a virtual windows XP machine then use the correct drivers and cutstudio.
Large Format, Sublimation, Direct To Garment Wholesale Manufacturer. No Minimums
AlanD
Post by AlanD »
I'm surprised you can't get this plotter to run, I think any sign programme would run it and you can even get cheap pluggins for Corel Draw. I thought there was even a print driver for Rolands, I think virtually any hpgl driver would run it. Getting rid of a good cutter seems a bit drastic.
spongerobinson
Post by spongerobinson »
did a quick google for you. here's a link with drivers right up to windows 8. http://support.rolanddga.com/_layouts/R ... x?pm=GX-24
edit: wrong product - sorry!
spongerobinson
sorry, my bad - i googled gx-24 which is the newer model! :frown:
Dave271069
Post by Dave271069 »
hello from sunny Rhoose, not too far from you, im using a silhouette cameo but to find a supplier in Cardiff i don't think you will unless hobbie craft sell them, you can purchase them from MDP SUPPLIES OR several other of the usual suppliers, if you get any issues you can give me a pm and i can direct you in the right way, ps if you buy from mdp supplies before 6pm you get next day delivery
malfunction
Post by malfunction »
I used to have a cx24 and i'm sure I used to run it on a windows 7 pc using vinylmaster (you can download a demo of it but it will only let you cut sample files) there is defiantly a driver for your cx24 in the program, it will at least let you know if it's compatible. I think "signblazer" will work as well and thats a free download.
If you decide to go for the cameo have a look on graphtecs website they do ex shopping channel cameos for £200 inc vat. The cameo is a decent machine but it's slow and limited re vinyl size compared to the cx24.
I would persevere with the rowland if it was me.
AlanD
Post by AlanD »
Ditto - the Cameo may well be a very good machine but if it is aimed at the craft market I suspect it may not be as robust as a larger plotter aimed at the sign market.
spongerobinson
It should definitely work without a Roland driver, with some of the commercial software available. Your main issue is interfacing it with your computer. You'll need a USB to parallel adapter probably.
There are some posts here about getting this working with Windows 7, and people seem to have been successful using the GX-24 driver.
http://www.t-shirtforums.com/vinyl-cutt ... 53631.html
tiamaria
Post by tiamaria »
many thanks for all above replies ,i will try again tomorrow getting it to work with my win 7 machine if i can not get it to work i will then get the cameo cheers all
