Mug pressing - typical problems
SteveHart
Re: Mug pressing - typical problems
Post by SteveHart »
I saw a video on youtube where a factory (machine) was processing mugs and slapping on silicone wraps and plunging them into an oven. I had the impression they were doing this without human intervention.
Your question and my question is how do these companies print mugs with consistent results? If it is such a dark art then how do these companies automate it?
SteveHart
Post by SteveHart »
OK - tried dunking mugs in a sink filled with hot water straight out of the tap. I think this is still too cool. Whilst none of the mugs cracked visibly, I think some cracked "non-visibly". I could hear a cracking sound and see what looked like crack lines in the water, but once removed there was nothing visible. What I do now is boil a kettle and fill the mug with boiling water before dunking. Could be a pain if doing 100 mugs.
I think if you are going to dunk then it has to be pretty close to 100c. Certainly not cool enough to put your hand in. You could keep a pot of water on boil.
I have to point out that not all designs have problems with bleeding. For me, it seems connected to the colour yellow and how close it is to the front of the mug.
SteveHart
Post by SteveHart »
One thing that was never clear to me as a newbie was the heating up times/instructions. There is a lot of advice out there saying let the mug warm up for 2/3/4 minutes. I think this is from people who don't have a thermometer on their press. I don't know if this is common. Mine does.
When I first turn on the press (I have an old, blank mug in there already) I let it warm up to 170c. I'm also warming up the mug I'm going to print at the same time by holding it above the press. When the press gets to 170 I take the old mug out and put my mug-to-print in. The temperature drops straight away. So I need to wait for my "mug-to-print" to warm up. That's now two warm-up phases. Once my mug-to-print gets to 170 I then turn on the timer to 90secs. Once that mug is finished I put in the next one. Once again the temperature drops and I have to wait for it to rise back up to 170.
Gvido
Post by Gvido »
Hi, Steve!
Your post was very useful, thank you!
But I got some questions:
I got problem that there is yellow line a round black color:
vB_ID:5594
vB_ID:5594
So this mean that I use too high temperature? I use 360F to 180sec.
Maybe I got yellow line because I use regular cooking paper not specialized?
Also, could you please explain the point of dunking mugs? I have found many opinions on this. Do you find big difference between dunked and non-dunked mugs?
Have you tried to sublimate anything on latte mugs? I found out that you must have special design because mug is narrow on the bottom but wider on top.
