Cap heat press
pw66
Re: Cap heat press
Post by pw66 »
Did anyone get around to recomending a decent cap press the post got a bit side tracked.
TQfan
Re: Cap heat press
Post by TQfan »
no, no recommendations.
figured out my cap press was broken, which is why it didn't do it's job. oh well.
Pixelpusher
Re: Cap heat press
Post by Pixelpusher »
The stahls hotronix maxx cap press is great and you can chance the bottom platens to suit different style caps, a bit more than their basic model cap press, but as said features the option to change it a bit. :)
Re: Cap heat press
I purchased the ball press from Coralgraph and have to say, the one I have is very well made and very sturdy. Mine came with a cap press platen as well as the ball press so you might want to give them a call and make sure this is still the case.
I will point out that although it is very well made and I think is probably very durable, I have only used it a handful of times so can not guarantee it
TQfan
Re: Cap heat press
Post by TQfan »
got this one in the end|
vB_ID:5794
vB_ID:5794
vB_ID:5794
vB_ID:5794
vB_ID:5794
vB_ID:5794
vB_ID:5793
vB_ID:5793
vB_ID:5792
vB_ID:5792
pw66
Re: Cap heat press
Post by pw66 »
That Galaxy Pluto range ( cap and flat presses) looks 'almost' identical to the Stahls basic range - which is made in China.
juggysingh
Re: Cap heat press
Post by juggysingh »
Hi socialgiraffe, does your press look like the image in the link below, and also what is the size of the cap press platen too please?
http://www.globalmarket.com/product-inf ... 89833.html
Im also looking at a Bluewave Cap Heat Press on ebay (£99), the press will be used for inside garment labels and outside small htv on my t-shirts, so any suggestions would be greatly appreciated too.
https://www.ebay.co.uk/itm/CAP-Heat-Pre ... 0967951751
Earl Smith
Re: Cap heat press
Post by Earl Smith »
Is your design made with the Oki White?
[QUOTE=TQfan;138969]got this one in the end|
[/QUOTE]
Re: Cap heat press
http://www.globalmarket.com/product-...-11089833.html
https://www.ebay.co.uk/itm/CAP-Heat-...-/270967951751
Yes it does look exactly like that.
The flat platen is 120 mm x 120mm
I have a small pocket press made by HIX that I picked up from Listawood. Pretty sure they do not sell it anymore but you are the second person who wants something similar, might be worth giving Chris a call and see if he can get hold of more of them. That press is 160 wide x 90 deep.
gavtheoldskater
Re: Cap heat press
Post by gavtheoldskater »
changing the subject slightly what sort of transfer did you use for those caps TQFAN, is it a weedless film?
