When first starting out I bought one of the multi presses with attachments and the cap attachment is a bit rubbish, I think
So we were hoping a dedicated cap press would be better??
Thanks.
thank you for the reply, I actually think the bottom plate does move �� I will certainly check it. Thanks again!gavtheoldskater;137714 wrote:I forget the make but I have a decent cap press and for ages mine did that too, I was convinced I had the wrong size plates.
however fiddling around one day I realised I could slide the bottom plate forwards, and that was the solution, now it presses perfectly. Might be worth checking if you can do that with yours.
did you get it sold, Justin?Justin;137661 wrote:Couple of folk coming to discuss buying the business Saturday & Monday so I'll update asap.
