Ricoh SG 3110DN How do you set it to Mirror the image?
Re: Ricoh SG 3110DN How do you set it to Mirror the image?
I also use the ricoh sg3110 and powerdriver and it does mirror if you tick the box
The power driver looks a lot different to what i use in the screen shot. Am i missing something because there is no mirror box to tick anywhere on mine?
When you go to print, do you select the Ricoh SG3110 or the PowerDriver? If you don't see PowerDriver in the list of "printers" then you don't have it installed. Assuming you are using a PC (not Windows 8) then download and install PowerDriver from here:JHP;64073 wrote:The power driver looks a lot different to what i use in the screen shot. Am i missing something because there is no mirror box to tick anywhere on mine?
http://www.sawgrasseurope.com/technical ... c-profiles
Thanks martin, cannot understand why on earth Sawgrass didnt mention this when i phoned them!
Powerdriver installed.
Maybe it was lateral thinking - an answer to a question without elaboration!JHP;64079 wrote:Thanks martin, cannot understand why on earth Sawgrass didnt mention this when i phoned them!
can i be having the same problem with a mac and using photoshop cs6
just moved from my epson to the ricoh sg3110dn and i can't get it to reverse image
hope someone can help
