PU coating
tracyreed
Re: PU coating
Post by tracyreed »
Thought I would experiment with some PU coatings from paint shop, first on ply, then mdf.
vB_ID:3303
vB_ID:3303
vB_ID:3303
vB_ID:3303
vB_ID:3304
vB_ID:3304
Greybeard
Re: PU coating
Post by Greybeard »
Can you give any details of what you used, spray or film, to do the coating with ?
Many thanks,
John
EDIT
Just found your earlier thread. Is this the ' Rasmart' you mentioned there ?
It's like doing jigsaw puzzles in the dark.
tracyreed
Re: PU coating
Post by tracyreed »
Hi, no the earlier thread was Rasmarts coatings, this is a specialised pu coating, the clear one works a treat, the white has a milky appearance which works with some prints but not others. I am working with a local chemist to try and find a way to sort it. My problem is I need a cost effective way to coat large (over 2 metre items). But Im getting there.
ArferMo
Re: PU coating
Post by ArferMo »
Thats the key Tracey..... cost effective, tends to be the downfall of too many products. Following your exploits with great interest.
JMugs
Has thanked: 10 times
Been thanked: 10 times
Re: PU coating
Post by JMugs »
Interesting, cost effective depends on what you can charge, so I will also be following with interest.
Janners
Greybeard
Re: PU coating
Post by Greybeard »
tracyreed;97643 wrote:............this is a specialised pu coating.......
I like the brilliance of the print. This is onto a pu coating on the ply ? I thought only polyester was possible, due to its chemical structure.
I can see I'm well down the learning curve yet.
I'm looking at a way to print onto small areas, typically 2cm x 10cm, so much less of a problem than you face, >2m, yipes !
John
Re: PU coating
synthetic polymers work, but some better than others.
as the ink turns to a gas with heat, the 'pores' of the polymer open up allowing the gassed ink in. the cooling down closes the pores and the ink resolidifies.
pressure from the heat press makes the gass go deeper into the surface in a more concentrated way, rather than spreading out.
more natural materials which are porous will obviously also accept the ink, but their pores are unaffected by the heat, they are always open/porous, so when the heat is taken away and things cool down, the pores don't close trapping the solidified ink, so the print isn't as permanent - it will wash out, rub off or just fade quicker.
Greybeard
Re: PU coating
Post by Greybeard »
Hi pisquee
I've started another thread about the chemistry of dye-sub and possible materials, so that it doesn't divert from Tracy's work.
John
