Hi Everyone, I have been searching, without luck to find the vapor foam kit available in UK.
Does any know where I can buy one please without having to purchase from overseas.
If not, Can someone help as I am about to start printing Vapor Basic Tees & all the videos I have watched mention you should use a piece of foam inside your tshirts to help reduce the print lines.
If anyone has any experience with printing vpaor basic tees I would gladly love your advice please.
Thanks in advance...
Vapor Foam Kit - Or Just The Foam
customprints
soulclaimed
Re: Vapor Foam Kit - Or Just The Foam
Ive found that tearing around the image helps to alleviate lines on other sublimation t shirts cant guarantee this will work for you it just breaks up the edge
customprints
Thanks for your reply... The problem is, I'm printing using the A4 printer there isnt any room left to tear the edges...
Is that the same as a teflon pillow?
http://www.xpres.co.uk/p-9018-textile-t ... xpres.aspx
http://www.yolo.co.uk/ptfe-teflon-pillows-565-p.asp
customprints
JMugs - What a shout that is mate
, Never even give a teflon pillow a thought... I'm not 100% sure, But surely they do the same thing...
I will certainly give it a go... Thank you very much for your reply...
I will let you know how it works out...
Ps. Thanks for the links too
icustomprints;98670 wrote:JMugs - What a shout that is mate, Never even give a teflon pillow a thought... I'm not 100% sure, But surely they do the same thing...
how did you get on with the Teflon pillow?
