Epson 1500w Reviews/Advice Please
Spike1865
Re: Epson 1500w Reviews/Advice Please
Post by Spike1865 »
Hi folks. I am wondering if the above printer will e good for sub printing? Anyone using it for this? If so where did you buy the CISS from. How do I set it up perfect :D
Thanks in advance,
Spike
James990
Post by James990 »
I use one, I modified the lid to the cartridge chamber, so that I could still have it on, and then fitted a CISS which I bought from Coralgraph. I also fitted an external waste tank, bought via ebay, so that the pads do not get clogged and leak every where. So far, three years down the line, it is still working wonderfully well.
James
Spike1865
Post by Spike1865 »
James. You're a star fella.
I can't really afford mistakes so this is a big help. Do you have a different printer for transfers and normal printing stuff?
rgds
Spike
Excellent 6 colour print, when I used mine I had cis from City Ink.
James990
Post by James990 »
I use the 1500w for the sub work, and a epson R220 for normal printing, so to speak. The R220 also has a CISS fitted and an external waste tank.
I also have a R220 in the house again with CISS and external waste tank. All the computers are in the same workgroup, so speak to each other and the printers. I only have the other R220 in the house because I am too lazy to go down to the workshop to collect any printing!
I buy all my ink in bulk, so that I can just fill up as and when I need to.
Don't get me wrong, it did cost a bit to get started, but I am glad a did buy what I bought.
James
Spike1865
Post by Spike1865 »
James990;99972 wrote:I use the 1500w for the sub work, and a epson R220 for normal printing, so to speak. The R220 also has a CISS fitted and an external waste tank.
James
Cheers guys. How much does the sub ink cost when bought in bulk and where is best to get it from?
Spike1865
Post by Spike1865 »
Hi guys. I am trying top buy a waste ink tank but its saying it doesn't include a reset code. Do I need one with a new printer?
James990
Post by James990 »
You should not need one with a new printer. But I would buy one anyway and have it handy. I bought one a while back and it is still valid, and it is there when I need it.
Spike1865
Post by Spike1865 »
Thanks James. Is this the correct CISS? http://www.ebay.co.uk/itm/NON-OEM-Ciss- ... 3386f2f824
Where do you buy bulk sub inks from fella?
James990
Post by James990 »
NO, that has bog standard ink in it, if you read further down it says - 'Note : this inks are not suitable for printing on mugs and tshirt'. You need one either with sub ink in it or empty and you put your own in. Suggest you send a message to Henry at Coralgraph - [EMAIL="sales@coralgraph.com]sales@coralgraph.com[/EMAIL]
James
