printable vinyl for skins - ecoselvent/solvent
Re: printable vinyl for skins - ecoselvent/solvent
Hi guys,
Any recommendation for some nice and thick vinyl to print laptop skins? I know there is some strong vinyl with grey glue but not sure if this one is ok and if its removable.
any ideas?
I appreciate any help.
Do you have the cut files Paul? I imagine these have to be very accurate?
Vinyl is bigger problem then templates buddy ;)
i did one for my macbook months ago and it was perfect fit ;)
Either MPD from Metamark (100 micron) or KPMF Air Release (from MDP) are both pretty good.
I am currently looking at some Fuji media and they have one which is a clear film, adhesive back that leaves no residue and can be re positioned as many times as you want. Have seen a few sheets and was thinking that may be pretty good for your needs.
Thanks simon. Will look in to them. not sure about clear stuff thou :)
The clear stuff works well with black designs on Apple laptops, or if like me, you can print white and metallic :tongue:
I cant :tongue:
and i prefer the white stuff...
cant find descent stuff for this job :/
still looking for some thick vinyl. :)
I remember i had laptop skin about 7y a go and it was as thick as 1mm or maybe little bit less. it must be available somewhere...
its not removable. but thanks :)
i think i found what i wanted.
