Doming Resin
The Housewives Favourite
Re: Doming Resin
Post by The Housewives Favourite »
Hi there people, just looking for some advice if possible, I use a 2 part doming resin from MDP Supplies, but have always found it dries really tacky and just never seems to dry 100% somehow, does anybody have and good suppliers for low volume doming resin or is there another way of getting it to dry, tried using uv but not sure it actually works to be honest or maybe the resin wont react to uv light i dont know but can anyone shed any light or any good doming fluid suppliers for low volume stuff
cheers
Re: Doming Resin
http://shop.acuflow.co.uk/
Don't bother with their online shop (not sure if it even works to be honest), but genuine nice guys, always want to help you, prices very reasonable and have found that their stuff works.
Re: Doming Resin
socialgiraffe;109608 wrote:http://shop.acuflow.co.uk/
thats great thank you, its been bothering me for a while i cant get doming resin that sets hard instead of flexi/tacky/hardish.....(have to be careful how that was worded) :-)
and prices are pretty good, to be honest i am not bothered if they are a little more expensive as the end product has to be right, cheap is not always good...do you use them?
scotty44
Re: Doming Resin
Post by scotty44 »
MDP only sell the semi flex if I remember right, acuflow has semi and rigid, Eddie at acuflow is spot on and will help as much as he can :)
You dont need UV light for this type of resin it will self level and set on it's own. When you say it wont dry? how long are you leaving it?
I use resin everyday and have done for a few years now, after trying different types, mixing my own 2 parts etc... acuflow is the only place I use now.
Liquid lens is good too but there not cheap! ...
Re: Doming Resin
scotty44;109615 wrote:MDP only sell the semi flex if I remember right, acuflow has semi and rigid, Eddie at acuflow is spot on and will help as much as he can :)
Been using mdp 2:1 ratio but just never seems to dry even after two days...picked a badge up after two days and left a fingerprint in it? Tried heat and UV and just not happy with it but not sure who to try as liquid lenses didn't help too much so acuflow might be getting a few little bits of business I think
scotty44
Re: Doming Resin
Post by scotty44 »
Scrap what ever you using for the UV, it wont help in anyway and you only use heat within 10 minutes of laying down the resin (leave it to long and it will form a skin and look pants when set)
If the resin is not good to touch after say 8-10 hours then it's not mixing correct! What mixing tips are you using white or green?
Steve @ Liquid is hard to track down but has always got back to me, he is a busy man and I guess gets alot of questions etc.. but their loss :)
Re: Doming Resin
Does UV not help at all? Its the clear white mixing tubes as they only sell those with their 2:1 mix so assumed it was correct as they sell that as a kit too? It sets.... Just not what I want it to set like...it's just a bit tacky, it's hard but after two days could put my finger on it and pick it up? Been printing for twenty years but only just ventured into doming so still learning this bit
scotty44
Re: Doming Resin
Post by scotty44 »
Nope no need for a UV lamp at all with this resin, the only time you will read about UV is when it says someing like "UV resistance" IE it wont yellow under the sun....
They will stay tacky for a few hours but I can dome a set at 11pm (yes I work silly hours lol) and have them bagged and ready to post by 10am
There are alot of factors with the resin, like the ink used, the vinyl/paper used, temp etc....but none of them will stop the resin from setting.
If you try acuflow ask for the green mixers, I rate them better than the clear longer tips :wink:
daveave
Re: Doming Resin
Post by daveave »
My friend owns Acuflow, give them a ring he will help you out and say Dave told you about it
They sell on eBay as well
INTERFAX ACUFLOW LTD.
UNIT 2b, REDDICAP HEATH ROAD
SUTTON COLDFIELD
WEST MIDLANDS
B75 7DU
PHONE: 0121 378 2289
FAX: 0121 378 2223
E-MAIL: [EMAIL="eddie@acuflow.co.uk]sales@acuflow.co.uk[/EMAIL]
Re: Doming Resin
yep indeed thank you for all who recommended acuflow, gave me the exact advice needed, spoke to a guy called eddie who couldnt of been more helpful, answered loads of my questions and is sending a sample out to try, so thank you for all your help, will keep you updated on the progress of my sticky badges :-) oh and eddie said to say hello dave :-)
Users browsing this forum: No registered users and 13 guests
