Oki C711WT White toner colour printer A4
Re: Oki C711WT White toner colour printer A4
Oki C711WT White toner/colour printer A4. Very little use, 22 months old, MINT condition, toners are half full. Comes with a couple of packs of different media and best part of a box of Yolo paper for easy application of white/colured transfers onto dark or coloured garments. Still have box etc.
Looking for offers in the region of £1200 - Can be demonstrated (based in Leeds, West Yorkshire). Cleared funds only. Questions welcome?
Cheers!
Nigel.
Cheers!
Nigel.
Desperate for space, printer is in my way... £999.00 open to offers!
Cheers!
Nigel.
Cheers!
Nigel.
What is the cost of a print?
Cheers
John
Cheers
John
If you buy the WoW 7.2 paper pairs in 50 pairs at a time then it works out at £3.60 per A4 transfer plus toner which is finger in the sky money say 10p real guess though then a white toner cart is £335 and the colours half that but they go a real long way.
I wont use WoW7.2 papers, they are too expensive, unreliable and wash terrible. Using Yolo Image Clip Laser dark 2 x 50 sheets the cost per print is approx £2.20 per A4 transfer and that's inc vat.
Cheers!
Nigel.
Cheers!
Nigel.
Looks like £2.45 per A4 pair at checkout. MUCH better than the WoW papers :rolleyes:
£1.80 per A4 sheet plus toner. ArferMo has quoted 7.2 papers which is for a standard CMYK printer, Nigel is selling the White toner bases system which uses 7.8 paper @ £90.00 for 50 sets. If you are using TMT papers then you might be able to swing a copy of their software out of them (SPACE CONTROL), this will save you bucket loads of toner and makes the toner cost stupidly low, I have had laser printers without this software and the cost is considerably higher.What is the cost of a print?
But why use 7.2 when you should be using 7.8? I admit that it takes a bit of practice to get used to the system, but once you do then I have found it to be the most durable and easiest to use. Also have you seen and tried T.one?I wont use WoW7.2 papers, they are too expensive, unreliable and wash terrible. Using Yolo Image Clip Laser dark 2 x 50 sheets the cost per print is approx £2.20 per A4 transfer and that's inc vat.
Stitch Up, if you are thinking of purchasing, the costs are above. However make sure you have a VERY good heat press (i.e. Adkins) and be prepared for a bit of learning. Once mastered though you will one happy chappy
£1.80 is cheaper than £2.45 in my neck of the woodsLooks like £2.45 per A4 pair at checkout. MUCH better than the WoW papers
So if on checkout at TMT a box of 50 WoW 7.8 papers is going to cost £120 delivered then to me that works out at £2.40 per A4 transfer delivered which is neigh on the same as the Yolo papers delivered price, still a lot better than 7.2 papers agreed, still hate the stuff though :frown:. Great for passing trade or items that won't get used a lot.
Probably, I always assume prices are plus VAT hence why I presumed it was considerably cheaper. I think the papers are both about the same and it really depends on what you personally prefer, I prefer WOW you YOLO, both are pretty much the same really.So if on checkout at TMT a box of 50 WoW 7.8 papers is going to cost £120 delivered then to me that works out at £2.40 per A4 transfer delivered which is neigh on the same as the Yolo papers delivered price, still a lot better than 7.2 papers agreed, still hate the stuff though :frown:. Great for passing trade or items that won't get used a lot.
Users browsing this forum: Amazon [Bot] and 7 guests
