My ricoh hasn't really been used that much as I've been concentrating on tees but I turn it on now and again to give it a wee turn.
I turned it on today and the boot up time was like 10-15 minutes and it has almost swallowed all the blue ink and now have a low ink message.
I've printed about 30 mugs in total
Anybody else had this problem, is this a problem with charging the ink system as it has been sat not being used?
ricoh 3110dn
Re: ricoh 3110dn
I would leave it turned on and let it go into sleep mode, will use a little ink doing it's cycle now and again, but less than a prime every time you turn it back on, turning it off may cause the heads to block up over time!
Re: ricoh 3110dn
scotty,
yes thought that might be the issue, test prints show head is ok, might bang it back on and let it go tp sleep, bloody expensive though!
