Converting file type.
Re: Converting file type.
My cutter will accept:
AI Adobe Illustrator (.ai)
EPS Encapsulated Post Script (.eps)
PS Postscript (.ps)
PDF portable Document Format (.pdf)
SVG Scalable Vector Graphocs (.svg)
WMF Windows MetaFile (.wmf)
DXF AutoCAD Drawing Exchange Format (.dxf)
HPGL Hewlett Packard Graphics Language (.hpgl)
RTF Rich Text Format (.rtf)
Is there any way of me converting my files to any of the above?
PS Postscript (.ps)
What format are your files in now?
Do you mean converting from a bitmap format to a vector format? I use VectorMagic.
Apologies. I meamt the cutter programme. I use gimp and photoshop. Will try Vectormaguc thanks WT
What software are you using now for your designs? Most programs should allow you to export as different files.
What are you trying to cut? Is it just text or images?
When you say you want to convert your files, what kind of files are these? and what software were they created in.
Could you post an image of what you are trying to cut please. What material are you cutting?
Vinyl. Its nothing specific at the moment to be honest just playing and getting used to things
