Replacement silicone sheet for wraps
daveave
Re: Replacement silicone sheet for wraps
Post by daveave »
Would anyone know where to get a suitable replacement silicone sheet to use in these mug wraps
vB_ID:5158
vB_ID:5158
vB_ID:5159
vB_ID:5159
Do a search on this forum, there is a company that I used which was recommended on here but can not remember their name
Customprintwales
Post by Customprintwales »
I just buy baking sheet silicon from Amazon and cut them down to size. Then you just thread through the new silicon and away you go :)
You might need a little washing up liquid on to help the silicon go through the bars but it's pretty easy.
daveave
Post by daveave »
Thanks, will try some baking sheets, mine have worn out
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
Speak to BMS they used to sell it by the square meter if you asked then, as above, cut to size.
Janners
Why bother though when you can buy the green wraps for a fiver or less from fleabay?
Users browsing this forum: Semrush [Bot] and 2 guests
