Anyone ID the Font in this Logo
Stitch Up
Re: Anyone ID the Font in this Logo
Post by Stitch Up »
Sigma
vB_ID:5673
vB_ID:5673
Figgy
Post by Figgy »
It seems to me that it's Xenois Semi Pro Bold :)
Stitch Up
Post by Stitch Up »
Thanks Figgy - I did try and ID this with the various sites but no luck.
It certainly does look like [LEFT]Xenois Semi Pro Bold - unfortunately it's not a free font.
Thanks very much
John
[/LEFT]
Stitch Up
Post by Stitch Up »
If anyone does have this font, would you be so kind to type the two words in the design and the symbol in the midle and email to me?
I'ts just not worth buying the font for just this one logo!
John
you can vectorise it without retyping it. or you need different wording too?
Stitch Up
Post by Stitch Up »
No Paul, exactly as it is.
I did try running it through Vector Magic but the results were pretty grim - it was rather a hurried attempt!!
Have you tried myfonts.com?
Pretty sure you can type in your choice of words/letters
Once done you could try creating a PDF, although you will probably have more luck doing a screen grab and then running a trace from that. The reason I suggest this is because you will get all the letters in black and I think you can zoom in making a nice big file to trace
I hope I have explained that clearly enough ;-)
Stitch Up
Post by Stitch Up »
I need to spend some time to vectorise the design :)
Hi John.
Just had a quick go at this. It's not perfect because the original image isn't great, but here you go ...
[ATTACH]5678[/ATTACH]
Let me know if you need .ai or .svg files instead.
Stitch Up
Post by Stitch Up »
Thanks for that Webtrekker :)
I managed to get similar using tracing software.
I must learn to use Coreldraw more effectively! Time is always the issue for me.
I do find the tracing function in Wilcom ES3 to be far easier to use than Coreldraw yet Wilcom ES3 is based on Coreldraw!
