Hi all
What is the best angle blade to use for a better cut on vinyl 30 or 45 or 60 ???
Azz [FONT="] [/FONT]
Angle blade
Re: Angle blade
The degree of the blade generally relates to how thick the material that you want to cut is. A 60 degree blade will cut much thicker material than a 30 or 45.
For vinyl I would (and do) use 45, its a good all rounder and works perfect for my needs. I suspect a 30 degree will be just as good though
Re: Angle blade
Thank you socialgiraffe i've been using the same one that came with machine but lately been using different thickness of vinyl and hasn't really cut it well.
Re: Angle blade
I would be very surprised if the poor cutting is due to your blade angle (unless you are cutting something like 3D build etc), put a new 45 degree blade in and see what happens, also check your cutting strip to make sure that is still perfect.
