CorelDraw Cutting Master v3 Plug In Issue
Any OS, software in here.
Re: CorelDraw Cutting Master v3 Plug In Issue
I'm sure we've discussed this before but I can't find it for the life of me!
I use the plug in for my Graphtec cutter with CorelDraw and it's always worked well. I've just reinstalled CorelDraw and then plug in has stopped working.
I've reinstalled the plug in, repaired CorelDraw, reset defaults etc. but it just won't work.
I get the error "Could not connect to CorelDraw"
I have no idea on this specific issue, but have you removed the plug in, drivers etc for the plug in and then tried to reinstall?
I am basing this on perhaps you need to do it in a specific sequence... i.e. install Corel and then install plug in.
Yeah, that';s what I was hoping was causing the issue but alas not worked.
I had this a while back but can't remember how I fixed it!
