Hello,
I've heard a lot about sublimation on polyester and was just wondering if you could also sublimate on 50-70gsm spunbond polypropylene (a non woven material)?
Thanks!
Can you sublimate on spunbond polypropylene?
Re: Can you sublimate on spunbond polypropylene?
I would think you could. Might have to fiddle with the heat level and time as I believe it is quite a thin material but should take a print. How well though is a different question.
try ironing a sample with domestic iron on hottest setting ... what happens to it?
Thank you Andrew and logobear for your responses, much appreciated! I will pass the advice along to the company that I was working for during the holidays.
Fabric wholesalers send out samples (usually free) - so get a sample and test it.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
