black ink
smitch6
Re: black ink
Post by smitch6 »
my black in seems to be coming out dark blue and not black :confused:
i usually use 180 C for around 300 seconds
smitch6
Re: black ink
Post by smitch6 »
i should of said it is just text
i printed a picture with lots of black on and that came out great :)
but the verse i done in black came out blue
Andrew
Re: black ink
Post by Andrew »
Assuming it is a mug, 300 secs is far to long. Try 180 as a starting point and see how you get on. It can be quite hard to get a true black but a bit of fiddling should get you there.
NASH
Re: black ink
Post by NASH »
i get true black @ 180* for 180 seconds
Re: black ink
If blacks are black then are you sure the text is 100% CMYK? If it is dark looking on screen it doesn't mean it is true black.
Warrior
Re: black ink
Post by Warrior »
I convert all text to 100% Black RGB,,,,,,,,,,,,,,,,,
John G
Re: black ink
Post by John G »
Far too long on the time if its a mug - take it down to 170 - 180 and give that a try. Failing that it could be your colour settings.
jennywren
Re: black ink
Post by jennywren »
I just doing mugs with a all black logo, which is always a mare on bms musgs, I had to turn down the temp a bit to get the black I needed, which also reduce the paper line where the top and bottom lines are, ( you could see where the paper started and ended which gave a whiter shade at top ond bottom) Hope that makes sense, Got it off pat now, this is the first time i have used their mugs and I am quite pleased. Love they way they are packed, we only at the moment offer a pick up service and am think of posting 36 mugs, we do indivual mugs but not bulk. Well done Martin
