Is anyone using a GRaphtec CE6000plus and the latest Coreldraw? Just purchased an unused Ce6000plus cutter but cant get it to work with my Coreldraw 2020
Everytime I try and cut I get an error message
Running Coreldraw not Found
Can anyone help?
Graphtec CE6000plus and Coreldraw2020
Re: Graphtec CE6000plus and Coreldraw2020
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
You will need to download Cutting Master from Graphtec..
It is a free plugin which installs in CorelDraw and lets you cut direct (also works in Illustrator)
Make sure you have the full version of Corel though as I don't think it works with the cut price student edition.
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 3 times
Ditch Corel and go with sure cuts a lot pro.
So much better and easier to use.
Mrteajunkie;144737 wrote:Ditch Corel and go with sure cuts a lot pro.
I'm with Mr T on that. I've used it for well over 5 years now for all of my cutting.
Why ditch corel if that is what the OP has always worked with? They may use it for other work not just to cut stuff, not a really helpful answer. I have an old Graphtec 7500 that is connected to an old XP laptop, which is not connected to the internet, but to my network, that I use for cutting my garment vinyl. This is because I have a workshop and studio. I can open the file on the XP laptop in an old version of coreldraw and then use cutting master 2 to cut the file.
Or as the second poster says try the Cutting Master download and see if that connects.
