Hi all
i just got my first heat press machine but have a few concerns / questions.
when opening the box the base plate is all scratched (see attached photos) however came with a cloth that appears to go over.. other than cosmetic / and thinking a new machine shouldnt looks like this
is it going to have any detrimental affect on use? (see photos)
secondly on the swing away press there is a foam piece that is starting to peel away. Should this be doing that? (see attached photos) or is this protection cover for transportation that i can peel off ?
Grant
new machine - help
grantsmith82
Re: new machine - help
- vB_ID:6387
- WhatsApp Image 2020-09-29 at 12.51.00.jpg (37.61 KiB) Viewed 178 times
- vB_ID:6386
- WhatsApp Image 2020-09-29 at 12.51.05.jpg (25.2 KiB) Viewed 178 times
- vB_ID:6385
- WhatsApp Image 2020-09-29 at 12.51.06.jpg (26.57 KiB) Viewed 178 times
- vB_ID:6384
- WhatsApp Image 2020-09-29 at 12.51.05 (1).jpg (33.61 KiB) Viewed 178 times
- vB_ID:6383
- WhatsApp Image 2020-09-29 at 12.51.01.jpg (35.99 KiB) Viewed 178 times
- vB_ID:6382
- WhatsApp Image 2020-09-29 at 12.51.02.jpg (38.07 KiB) Viewed 178 times
- vB_ID:6381
- WhatsApp Image 2020-09-29 at 12.51.03 (1).jpg (33.44 KiB) Viewed 178 times
That foam pad should be firmly glued to the lower platen, not hanging from the top platen....
Send it back for a full refund.
How did you pay?
How did you pay?
