PROBLEM with PRINTED PHOTO - SG3110 (photo not recognizable)
Strmecki
Re: PROBLEM with PRINTED PHOTO - SG3110 (photo not recognizable)
Post by Strmecki »
Hello,
I have printer Ricoh 3110dn. Today when I printed one photo, photo came out totaly strange (not clear). This is first time for me and I tried to change setting once again but result is the same.
I use Sublisplash colors, I have ICC profile and I'm working in Photoshop. I also tried to change setting: IMAGE - MODE - RGB or CMYK but result is the same. I also do nozzle check.
Does anyone have idea what to do and which setting I must check once again? I must finish one order so I will be happy for your help!
Regards,
Anze
vB_ID:6471
vB_ID:6471
vB_ID:6470
vB_ID:6470
vB_ID:6469
vB_ID:6469
Mrteajunkie
Been thanked: 3 times
Post by Mrteajunkie »
What’s wrong with It?
until pressed it will not look anything like the original picture.
Strmecki
Post by Strmecki »
I tried smaller photo but it's not ok.
[ATTACH=CONFIG]6472[/ATTACH][ATTACH=CONFIG]6473[/ATTACH]
[ATTACH=CONFIG]6474[/ATTACH][ATTACH=CONFIG]6475[/ATTACH]
vB_ID:6475
vB_ID:6475
vB_ID:6474
vB_ID:6474
vB_ID:6473
vB_ID:6473
vB_ID:6472
vB_ID:6472
Dynamic Grafix
Post by Dynamic Grafix »
Strmecki;146507 wrote:Hello,
Regards,
Anze
It could be the bit rate. Under the area where you changed from RGB to CMYK, you have options for 8 bits, 16 bits and 32 bits.
If this is a screenshot from a new iPhone, they're now 16 bit which can cause this issue. Change it to 8 bit or vice versa for something different thing to try.
