New Heatpress + Mug Press
Re: New Heatpress + Mug Press
As you will have noticed from my intro this is a new venture for me, my normal day-to-day business is in the Networking and Wireless and telephony industry.
As this is all new to me I'm looking and don't know any of the brand names as yet, Iv'e done a little research and come up with the following, also I'm not sure if you would go with a 5-in-1 press or a dedicated press and then look at a mug and hat press. Anyway here is what I've come up with.
Silhouette Cameo 4 pro cutter
PowerPress Industrial-Quality Digital Sublimation Heat Press Machine for T Shirt, 15x15 Inch, Amazon have them but out of stock.
https://www.amazon.co.uk/dp/B0773Y1TNX? ... otcri01-21
These guys do a mug-press starter kit which includes a printer
[TABLE="width: 379]
[TR]
[TD="class: xl64, width: 379]https://subliblanks.com/products/galaxy ... ter-kit-02
What are you thoughts on this?
Thanks,
Chet[/TD]
[/TR]
[/TABLE]
[TABLE="width: 379]
[TR]
Thanks,
Chet[/TD]
[/TR]
[/TABLE]
I would always recommend going for seperate presses rather than a 5 in 1.
You're better off buying from one of the better known suppliers. We use SubliBlanks for some stuff and they've always been very good.
Cameo will be ok to start with but very slow, better to look for a larger machine if funds allow.
What would recommend, also what's your recommendation on Heat PressesJustin;148627 wrote:Cameo will be ok to start with but very slow, better to look for a larger machine if funds allow.
Thanks,
All depends on your budget really. We always say buy cheap buy twice, so many people buy a cheap press and end up having to replace with a decent one shortly after and spedning more in the long run.
That said I appreciate that anyone just starting out may only have a small budget. There are cheaper presses around that should do the job.
Same with the cutter, more you spend better you get but you don't neccesarily have to spend big. Will it be used for t-shirt vinyl designs?
What type of things will you be printing?
Starting of with T-shirts, Hoodies, caps and such - nothing too big right now, I would rather get it right now though than have to purchase again later on.
Let me know your thoughts on the press too.
Don't be tempted to go A4 to save money as you'll need the larger press. If you can find a second hand Adkins on Fleabay or local they can be picked up for a good price and are excellent presses, same with Pressmech but you don't see many of those.
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 3 times
I have the mug press from mdp and I have the free sun 4050 press and I’m very happy with both.
you don’t have to spend £1000’s but don’t buy cheap eBay or Amazon all in ones.
OK hopefully this will close this thread off, what's your thoughts on this kit as a starting point, all from MDP
Mug Printing
Mug Press Touch Screen - Black
Sawgrass SG500 Pack - 31ml Full Inks
Sawgrass A4 sublimation paper
6oz heating element
Orca 11 Oz Standard - 36
1 x 1cm heat tape
36 x Smash proof mug shipping boxes
Jetcol DHS Subli Paper - Mug
T-shirt/Polo
Free-Sub 4050 Heat Press
Craft Cutting Mat Self
Teflon Sheet 500 X 400mm
Silhouette Hooked Weeding Tool
DeTape 8mm Art
Mug Printing
6oz heating element
1 x 1cm heat tape
T-shirt/Polo
DeTape 8mm Art
- Mrteajunkie
** Sawgrass SG500 Pack - 31ml Full Inks
** Sawgrass A4 sublimation paper
6oz heating element - I have two of these available if you are looking to buy?
** 1 x 1cm heat tape. -
Jetcol DHS Subli Paper - Mug. - AVOID THIS PAPER IS JUNK. (Get mug paper from ink experts)
T-shirt/Polo
Silhouette Hooked Weeding Tool - I use dental picks cheaper and sharper.
** The printer, inks and paper I would get from inkexperts. Along with heat tape. Far cheaper and better results and support.
A4 starter printer setup.
https://www.inkexperts.co.uk/product/su ... -a4-paper/
Mug paper
https://www.inkexperts.co.uk/product/in ... ion-paper/
Heat tape
https://www.inkexperts.co.uk/product/he ... -30m-roll/
T-shirt/Polo
Mug paper
Heat tape
