Epson Printers - Automatic Daily Print Test
Re: Epson Printers - Automatic Daily Print Test
Looking to run a daily test print to the printer, ideally a nozzle check or similar. Is best way to schedule a small print to run or is there a clever bit of software I havn't found yet that will do it for me?
I presume a wide format printer in which case I can not help.
But if its a desk top, then just set a reminder on your phone and send something using the Epson app on your phone.
Seems a bit of over kill to be doing a nozzle check everyday though matey.
You could probably do this using the in-built Windows Task Scheduler. It could run a .bat file or a PHP script at a set time each day.
Mrteajunkie
Been thanked: 3 times
Post by Mrteajunkie »
I believe this does what you need.
https://www.cmd2printer.com/
it would have to have a print rather than a test print but you can print whatever you like whenever you like.
socialgiraffe;149715 wrote:I presume a wide format printer in which case I can not help.
Epson 1500's, I'm not in everyday at the minute so just want to keep things moving.
[MENTION=1]Justin[/MENTION]
Harvey Head Cleaner
Have a look at this Justin ...
Ah yes, saw that years ago if I remember correctly! lol.
Are you still running on Linux, Justin? Not sure whether it's a Windows or Linux solution you are looking for.
Another option that seems quite nice, and doesn't involve anything other than inputting a few basic settings and scheduling a job to be run at whatever times you like.
Qimage Ultimate - http://www.ddisoftware.com/qimage-u/
https://www.youtube.com/watch?v=ZHqneKbQtmI
@Justin
14-day Free Trial - http://www.ddisoftware.com/qimage-u/trial.htm
