Tightening bolt snapped while securing heat band.
StreetsWs
Re: Tightening bolt snapped while securing heat band.
Post by StreetsWs »
Hello,
Is there anyone with any advice for this? I tried to contact Listawood where i got the genie III from I got a fairly vauge response saying I should go to a DIY shop and get a new bolt, but no actual advice on how to solve this? Image Attatched.
[ATTACH=CONFIG]6797[/ATTACH]
Any help is appreciated,
Many kind regards,
Streets Workshop
vB_ID:6797
vB_ID:6797
StellaD
Post by StellaD »
Do you mean some of the bolt is stuck in the thread of the machine?
If so you will have to drill a small hole in the stuck part and use a bolt extractor.
Places like Screwfix do them https://www.screwfix.com/p/bolt-extract ... lsrc=aw.ds
or Toolstation, bound to be at least one of those in your area.
Mrteajunkie
Been thanked: 3 times
Post by Mrteajunkie »
Grab a tiny screwdriver and gently tap the screw thread back out.
then go to your local diy store and get a new thumbscrew most likely 8mm or 10mm depending on your press.
