EPSON SC-F100 colour issues etc
Re: EPSON SC-F100 colour issues etc
I have been struggling with getting accurate colours from my epson. To cut a long story short the ICC profile was missing from the driver which messed things up until epson and me worked out what was going on.
But, even though the results are better, they are some distance off the original art on screen and the accurate results I got from my old Ricoh (that died). Messed up in the green and blue side of things. As I sell coasters etc online I want consistency with my existing product pics etc see no reason why I should put up with a substandard profile.
Any ideas where I might find a better ICC profile, the Epson one doesn't cut it. Or where I could get a profile made?
Guidance on heat press times for Epson inks and paper was not provided. (I bought the Epson package deal with inks and paper). Trial and error gets expensive. Less time by about 1/3 to1/2 seems about right (glass coasters, wood coasters, ceramic tiles)
cheers,
Jon
cheers,
Jon
- UK Printed Mugs
Sorry to say there are threads on here that basically say the Epson F100 doesn't give accurate colours. I've known of at least two large companies ditch the printer after a week. I believe if you're designing in-house and clients do not know the difference then you're fine but if you're dealing with client artwork then I don't think you're able to get good enough accuracy. We ourselves have done trials with all the printers on the market and our conclusion is that only the SG400 with a custom profile gives accurate colours. SG500, Epson models modified for sublimation as well as the F100/F500 are not good enough.
All I can say is you are not the only one to suffer with colour issues using Epsons own sublimation printers. Search the forum - there are some posts about the F100 and F500 colour issues. The next issue is you will be told you have exceeded the duty cycle of the printer (used it too much).
Ink Experts can make you a good profile. They are forum members and very knowledgable about sublimation. https://www.inkexperts.co.uk/ When you have used your epson ink it might be worth trying Inktec Sublinova.
Thanks for that. That is bad news. . I shall look up the SG400. I did a search for EpsonSC F100 before I posted but I must have mispelled or something as nothing came up. I will pursue this with the printer supplier. .
What was the limit reached? I don't print a lot compared to a more commercial operation but I had that issue with an old Epson inkjet back in the day. It is so cynical. I will contact Inkexperts, thankspw66;150500 wrote:All I can say is you are not the only one to suffer with colour issues using Epsons own sublimation printers. Search the forum - there are some posts about the F100 and F500 colour issues. The next issue is you will be told you have exceeded the duty cycle of the printer (used it too much).
Someone on the forum with a F500 had issues when they tried to make a warranty claim. They had printed quite a lot, but nowhere near as much as you would hope for from a £2k machine.JBA;150502 wrote:What was the limit reached?
https://www.dyesubforum.co.uk/vbforum/s ... light=f500
Is the SG00 as bad as the Epson? The SG400 is discontinued so that is out and mine is dead. What alternatives for the same price(ish) are there? I am seriously thinking of sending the epson back but need an alternative that isn't twice as expensive. thanksUK Printed Mugs;150499 wrote:Sorry to say there are threads on here that basically say the Epson F100 doesn't give accurate colours. I've known of at least two large companies ditch the printer after a week. I believe if you're designing in-house and clients do not know the difference then you're fine but if you're dealing with client artwork then I don't think you're able to get good enough accuracy. We ourselves have done trials with all the printers on the market and our conclusion is that only the SG400 with a custom profile gives accurate colours. SG500, Epson models modified for sublimation as well as the F100/F500 are not good enough.
Maybe the Epson L805 from Ink Experts. About the same price as the F100. Six colour photo quality printer using Inktec Sublinova inks, properly profiled.
Just my 5pence worth - F500 prints amazing quality and never had an issue with the colours. Only software/driver is terrible
Reference your issue with F100, keep the epson and inks as they are good and cheap. Make a custom ICC and you should be good to go. At least next time when you use epson ink you know they are consistent and they wont disappear from the market like some cheap inks.
I would love to create custom ICC for you but I am so busy right now, That I don't even know where is my spectrophotometer
I know there are some inks companies out there who will do it for you. cost currently is about £35/£50.
If you wont be able to find anyone, i will do a browse for my gear!
- UK Printed Mugs
I might be wrong, wouldn't be the first time!, but I'm sure that you cannot use a custom profile with F100 from what I remember a friend in the industry said. I think you are tied down to the Epson.
