Sublimation is pale sad on polyester bag
yvesima
Re: Sublimation is pale sad on polyester bag
Post by yvesima »
I tested sublimation on a 100% polyester canvas bag
Sekabo A3 Press
Paper poly 120
Printing on Sawgrass 800
Silicone mat between the heating plate and the bag
Choice on Print manager: Polyester Fabrik
The supplier tells us:
Temperature 205° C
Time 30 seconds
Pressure 5 medium
The first try is pale, sad the black is not frank
We increased the pressure then went to 45 seconds.
the result of the black is a little better but not frank
Does anyone have an idea ?
Thank you[ATTACH=CONFIG]6906[/ATTACH]
vB_ID:6906
vB_ID:6906
Increase the time further. at least 60 secs
yvesima
Post by yvesima »
i ll try that
Is it useful to put a rigid cardboard in the bag?
THANKS
You shouldnt need to but wont hurt to try something inside.
yvesima
Post by yvesima »
THANKS THANKS
have a good day
ill try and report to you
"Silicone mat between the heating plate and the bag"
Maybe that's what is causing the issue. Either remove the mat and replace with a sheet of paper (greaseproof, or baking, or butcher's paper, ... whatever it's called down your way), or, as Justin has replied, increase the pressing time.
pw66
Post by pw66 »
Are your RGB values set at 0,0,0? Sometimes if you are converting from cmyk you are not getting a true black.
yvesima
Post by yvesima »
HI thanks all is ok about colors and for black.
yvesima
Post by yvesima »
Thanks for your reply about silicon
ill first try the pressing time and after the silicone
If i ve time i ll try that to day
THANKS
yvesima
Post by yvesima »
About my question
It works
I ve put more time and just a lillte pressing more
It works
THANKS
