Ceramic Pet Bowls
Rachaelx777
Re: Ceramic Pet Bowls
Hi, I've just started with these and wondered if anyone else has had success with them in the oven? I have the orca ones from Neil brothers in large and standard size but finding the wraps I purchased off ebay aren't giving me sharp finishes regardless of temp/time. I am wondering if shrink wrap would be better but unsure which size would be required.
If your wraps are tight around the bowl then try dipping them in warm water as soon as you take them out of the oven. The blurry image is caused by the substrate being still hot enough to sublimate and the paper moving.
I have done breakfast bowls and used shrink wrap which worked very welll with very fine detail. I left them to go cold before removing the film
