The Electric Bill !
AdamB
Re: The Electric Bill !
Post by AdamB »
Has anyone ever worked out how much it costs to run a heat press, mug machine etc?
I was just wondering as our first 'electric bill' has landed on the door step so I started to go through exactly whats pulling the juice.
We have a few (about 20) floresent strip lights that drain a little (I went round turning things off and looking at the meter), but I was just wondering if anyone had actually worked out how long it takes to run a press for an hour?
Stitch Up
Post by Stitch Up »
You can purchase plug/sockets which measure the consumption of any appliance plugged into them. They work very well and atm for sale in either Lidl or Aldi
AdamB
Post by AdamB »
Stitch Up;16837 wrote:You can purchase plug/sockets which measure the consumption of any appliance plugged into them. They work very well and atm for sale in either Lidl or Aldi
Thanks john - I'll have a look next time I'm passing.
Did the 'packages' arrive ok mate?
Stitch Up
Post by Stitch Up »
Yes, all arrived thanks Adam - haven't opened the boxes yet!
If I'd remembered you were just up the road in Aberdare, I could have collected and saved you some money!
Large presses are 2kw/hr. Mug presses are around 350/400 watts per hour. Combination presses using the flat bed press are about 1.4kw/hr. A kw/hr costs around 12p ish.
Stitch Up
Post by Stitch Up »
bms;16842 wrote:Large presses are 2kw/hr. Mug presses are around 350/400 watts per hour. Combination presses using the flat bed press are about 1.4kw/hr. A kw/hr costs around 12p ish.
They don't draw their full wattage constantly?
Bob700
Post by Bob700 »
If you are the type of person who likes to work through the night (most of us don't) then you could change your electricty trariff to economy7 which is far cheaper to run during the night, economy7 is good for people who have electric storage heaters so they can build up the heat during the night a lot cheaper, it's usually around 3p a kw/hr
Stitch Up;16844 wrote:They don't draw their full wattage constantly?
True, these are guides which give an indication of consumption.
You can also borrow/buy energy meters whcih monitor the whole house and you can then put individual items on/off to see what difference they make.
AdamB
Post by AdamB »
Justin;16850 wrote:You can also borrow/buy energy meters whcih monitor the whole house and you can then put individual items on/off to see what difference they make.
Or you can switch everything off and look at the little spinny thing going around then turn things on one at a time - when it rotates more than than airhawkes blades you know that there's a pound puller on somewhere!
