Mug press shape types
GoldRapt
Been thanked: 8 times
Post by GoldRapt »
Hi All,
I am in the market for a mug press. The thing is I'm not a fan of "builders" mugs and prefer something with a bit of a curve. not just a latte shape but any shape that isnt a 10oz mug shape.
I was wondering if anyone knew what machine might take odd shapes like steins and latte mugs and other types please?
I'll be looking to buy previously owned as I don't want to spend a fortune on a new press only to discover what I want to try to do, doesn’t work and im not looking to press in high volume but I would readdress that last statement should things work out.
Thanks in advance for any help/advice/guidance
Tony
regards
Tony
-launching july/august 2026
JMugs
Has thanked: 10 times
Been thanked: 10 times
Re: Mug press shape types
Post by JMugs »
Latte mugs just use a "Latte Mug Press" and Steins are just a normal mug press but I used to put a piece of silicon cut the right size to allow for better pressure. Or use an oven and the appropriate wraps.
This link will give you ideas of new prices so you can work from there as to used values.
https://www.inkexperts.co.uk/product-ca ... eat-press/
GoldRapt
Post by GoldRapt »
mug shapes.png (832.41 KiB) Viewed 8293 times
So all of these shapes are printable, presuming they have the correct coating?
regards
Tony
JMugs
Post by JMugs »
Anything involving a curved surface would be a challenge. So straight and tapered sides do-able. Curved profiles would need somebody else to chip in.
