Hello, I have just bought a Ricoh GX e3300N printer and have installed PowerDrive-R.
I am unsure about the setting for Color Management. The guide on the Sawgrass disc is for CorelDRAW 12, X3 & X4, and appears to be slightly different for CorelDRAW11 in that when I open a new/blank page, then click Tools>Color Management, the window that opens does not have a radio button for RGB. All I get is Style: then a drop down where I can select Color Management Off. Prior to printing, I choose PowerDriver R, is this all that is required or is there any other setting I must apply on the Color Management?
Setup and Print Guide for CorelDRAW 11
Re: Setup and Print Guide for CorelDRAW 11
Hi Mo, I'm not sure but someone will be along soon with the correct info, you'll soon be operational. Why not give your settings a whirl, they may be OK.
V11 doesn't appear to be listed on the Sawgrass website
http://www.sawgrasseurope.com/technical ... r/gxe3300n
It doesn't matter what software you use when you use PowerDriver. Don't change anything in any graphics package and just print to PowerDriver. PowerDriver works with any software, Word, Publisher, PowerPoint, Corel etc etc
Hi Martin, thanks for the response, really has put my mind at ease.
Hello all,
Printed a few mugs last night...no problems at all. Thanks for the guidance.
