Hi chaps, I have switch on the Epson D120 to do a few mats, however, I admit that it's been approx 3-4 months since I have sublid, the ink light is on telling me that I have no black ink. I can't do a nozzle check or clean. Any ideas?
Regards,
George
Epson D120 low ink warning
Re: Epson D120 low ink warning
ok, got it working, printed ok for 2-3 sheets, now everything is yellow (????????) heeelllllp
Do a nozzle check
Hi Paul, did that, 3 times, no good, could it be my profile? I double checked my settings of the ICC profile. Strange, 1st 2 prints perfect, then it went t*** up.
So whwn you did nozzle check how is it look like??? Any lines missing?
If the nozzle check pattern is not perfect then there is no point going to print. Have a look at our FAQ on this matter (3rd up from the bottom)...georgess;33845 wrote:Hi Paul, did that, 3 times, no good, could it be my profile? I double checked my settings of the ICC profile. Strange, 1st 2 prints perfect, then it went t*** up.
http://www.printerowners.co.uk/faq/12/1 ... vanced.htm
I've got D120 (with CIS) and from time to time one of the colours stop working (even if using printer regularly). If it happens, I pull out cartridges, give them a good shake (cover "ink flow holes" to stop ink splashing all over) and it helps
I know it sounds bit silly but works for me
