brother 5910dw refillable carts install
bigj2552
Re: brother 5910dw refillable carts install
Post by bigj2552 »
installing the refillable carts into the brother printer.....instead of the usual hook above the magenta to fool the printer the door is closed - i got the tool seen below.....
the way its shaped, i presume it goes into the right hand side, next to the magenta cart.....only got 1, so dont wanna break it :eek:.
have tryed various ways...straight in - upside down, to the left/right of the original bracket thats there....nope.....
the other hook version went into the top....but this little bugger, i take it must go in the right hand side next to the original bracket, as its the same shape.....or i,m i wrong here ?
[ATTACH=CONFIG]991[/ATTACH]:confused:
johnny
vB_ID:991
vB_ID:991
bigj2552
Post by bigj2552 »
sorted.....had to take carts out again and re-enter them slooowly ...jeez .....and the wee plastic bit goes on at the right hand side as i thought......
bigj2552
Post by bigj2552 »
edit that....back to not finding carts ...ffs !..
double edit.....fickle dam things printers.....
had to elastic band the carts to the door so the door stayed half shut.....
bigj2552
Post by bigj2552 »
YAH....got the colours/drivers sorted out with both printers.....more grey hair but i luv it.
Tomorrow i will be spending most of it making up templates for the stock i have and for the rest to come next wk.
Gonna be a loooong day :rolleyes:
JSR
Post by JSR »
I use these cartridges (as you know) and I actually ended up with the wrong ones for my MFC5890CN (the tag on the magenta isn't long enough to get in the slot). So I just used a bit of bent plastic pushed into the slot and Bob's yer uncle. It sometimes comes lose if I jog the printer, but that'll teach me to print while half asleep! :biggrin:
The trick here (as mentioned in my original review) is to always put the magenta cartridge (or "bit of bent plastic") in *last* - otherwise the printer thinks you've closed the door and so won't recognise when you slot in the other cartridges.
It's all very logical, it's just that we humans aren't very logical... :wink:
bigj2552
Post by bigj2552 »
JSR;45472 wrote:I use these cartridges (as you know) and I actually ended up with the wrong ones for my MFC5890CN (the tag on the magenta isn't long enough to get in the slot). So I just used a bit of bent plastic pushed into the slot and Bob's yer uncle. It sometimes comes lose if I jog the printer, but that'll teach me to print while half asleep! :biggrin:
All good in the end jonathan.....might not be saying that tomorrow....but for tonight, i can sleep knowing a got something right today lol.....:tongue:.....eventually !
JSR
Post by JSR »
bigj2552;45473 wrote:All good in the end jonathan.....might not be saying that tomorrow....but for tonight, i can sleep knowing a got something right today lol.....:tongue:.....eventually !
I'm actually using the slightly smaller cartridges in my two A4 printers and the door closes fine with them in.
Good luck tomorrow! I wouldn't use anything else that's available on the market right now.
bigj2552
Post by bigj2552 »
JSR;45474 wrote:I'm actually using the slightly smaller cartridges in my two A4 printers and the door closes fine with them in.
what you mean ? - printer wise or cart wise ??
JSR
Post by JSR »
bigj2552;45483 wrote:what you mean ? - printer wise or cart wise ??
Both! :wink:
I've never been more content and less stressed than I am now using Brother printers and refills. Haven't touched my Epson printers for ages.
