Stopping my forum page from jumping up and down
Re: Stopping my forum page from jumping up and down
How do I prevent the forum page from jumping up and down every time the membership banner ad loads and reloads???
It's doing my eyes in !
This has been discussed a couple of times recently. Are you using an adblock or similar?
Some times nodding in rhythm helps nod
nod
nod
typing a bugger at times
nod
nod
I have it too, - only started about a week or two ago .....
did you not try what i suggested logo ????logobear;53693 wrote:I have it too, - only started about a week or two ago .....
Only happens on Firefox. I have ad-block plus disabled. The banner ad resizes and causes the page to jump It seems to be a problem with the rendering of the JavaScript element so I will play around with java to see if I can cure it. Shows OK on IE8.
Tried nodding now, I have neck ache too. Going to try viewing on a pogo stick.
Problem solved now updated Java and ABP.
Mine does this in Firefox and it's very annoying, making longer posts very hard to read as I keep losing my place.
I use Adblock and don't have any problems on other forums
Mark
Mark
- newsgroupmonkey
Does it for me too
I'm learning. So I'm probably spouting rubbish. Be patient :wink:
Have you both updated as mentioned above?
Are the other forums vBulletin based that appear to work ok?
