Some time ago i read a post on the brother printers being used for sublimation printing.
My question is this...?
What brother printers are people using these days and are you experiencing any problems?
Thank You For your time
Not sure of the logic here. So about 5 or 6 people using a Brother compared to 500 - 600 using a Ricoh (rough figures, but you get the order of magnitude!) - how do you jump to the conclusion that brother is better than the ricoh?meldean;55069 wrote: Sounds like a stupid question but if brother printers are proving to be better printers than the supported printers then aint it about time the ink companies get up to speed.
Well... Statisticly is 100% fautlessbms;55075 wrote:Not sure of the logic here. So about 5 or 6 people using a Brother compared to 500 - 600 using a Ricoh (rough figures, but you get the order of magnitude!) - how do you jump to the conclusion that brother is better than the ricoh?
On the other hand how can you be sure they aren't?bms;55075 wrote:Not sure of the logic here. So about 5 or 6 people using a Brother compared to 500 - 600 using a Ricoh (rough figures, but you get the order of magnitude!) - how do you jump to the conclusion that brother is better than the ricoh?
meldean;54989 wrote:Hello everybody.
Probs the same way you jump to the conclusion that i said they were better.bms;55075 wrote:Not sure of the logic here. So about 5 or 6 people using a Brother compared to 500 - 600 using a Ricoh (rough figures, but you get the order of magnitude!) - how do you jump to the conclusion that brother is better than the ricoh?
Users browsing this forum: Amazon [Bot] and 7 guests
