Dull colours while printing solved!
Re: Dull colours while printing solved!
On xpres paper supplied for my epson printer, they instruct the paper to go into the paper tray bright side up.
I have found this to be incorrect.
Placing it in dull side up gave a much stronger and sharper print on my mugs.
How odd.
All subli-paper is designed to be used bright side up, their instructions were perfectly correct as its the same for xpres, trupix and all other brands i'm aware of!
[CENTER]
Coldenhove Jetcol is printed on the dull/rough side, not the smooth/shiny side. It's in a roll, so impossible to load onto the printer the wrong way. I can't see that this is the only exception.
Surely it depends on the paper feed route ... or have I missed something? Then as Pisquee pointed out your paper type.
Am I just being a bit dim?
My Ricoh fed from the bottom tray, comes out the front, bright side down. Use a rear feed tray then it becomes bright side up.
When I was referring to "bight side up" I meant the side the image is printed on, not the way it is fed into a printer as you rightly say, it will vary from tray to tray and printer to printer depending on the paper path!JMugs;68495 wrote:Surely it depends on the paper feed route ... or have I missed something? Then as Pisquee pointed out your paper type.
[CENTER]
Unless epsons have changed feed path then you are doing it wrong - epson white up, ricoh white down, in the feed tray. If its working the other way around you may have set your printer profiles, or printer, up wrong.
I found with Xpres paper that the look of the sides varied in different light, and so I always used the wet finger test to find the printing side.
Jack
Jack
