Couple of questions please :-)
North guy
Re: Couple of questions please :-)
Post by North guy »
Hi guys.
can anyone tell me where I can get a4 sublimation metal?
looked at bms but they only seem to have a3.
also would someone be able to make me a template?
its for the diamond shape car signs that come from bms.
i just want something that I can save to my laptop that I can just open and edit like I do with my pet tags.
thank you in advance
Griff
Hi Griff
http://www.sublimetal.co.uk/ is the place for metal. Someone on here recommended them to me and I have placed a few orders with them and always been good.
North guy
Post by North guy »
Cheers mate, will check them out :-)
purpledragon
Post by purpledragon »
Bms do pretty mu h any size you want in sublimation metal unless things have changed since i last bought mine a couple of weeks ago
s31teg
Post by s31teg »
xpres do a good range for photos
purpledragon;71684 wrote:Bms do pretty mu h any size you want in sublimation metal unless things have changed since i last bought mine a couple of weeks ago
I posted a reply much alone the same lines but clearly information from us explaining this is considered advertising!
coz it is Martin. lets be honest.
purpledragon
i disagree if north guy had said hey i dont know where to get anysize metal and bms piped up with shop at bms we have all sizes then thats advertising
But north guy said bms only do a3 if martin then says no we do all sizes .then thats just martin correcting incorrect info
Or to put it another way if i said i need a profile for epson 1400 but paul only does them for a b1100 then going on your theory paul if you then told me no i can do 1400s too then you would class that as advertising?
With respect Bret. There is bit more then that.
purpledragon
Paul;71726 wrote:With respect Bret. There is bit more then that.
having not seen the reply before it was removed you have the advantage on me paul however martins comment and your comment are still public and so subject to scrutiny so with respect paul if you dont want threads commented on then dont place them in a public forum there may be more to it but i can only make comment on what is displayed and it does appear that martin had merely corrected some mistaken info . I might point out that at least 2 others have advertised other companies without their posts being edited or removed and quite right too itd be a bit daft having an info forum where info is removed
Just my opinion
