HI i know the lot of different advice of paper cutting techniques to using film and to different times to put different material on and even higher and lower temperature.
I'm just wondering what is working for everyone?
3D Sublimation Machine Technique , Heats and Timing
XpressDesigns
Re: 3D Sublimation Machine Technique , Heats and Timing
Don't use film. It really creates bad results due to the image never being exactly what you wanted. If you use film, pay for the expensive double layer film which has a rigid backing. You also should only use film with machines which are made to use it.
i agree, I found that with film, not very good for me and no extra befits.
I have found different temperature and times for different phone cases, i also use different cutting the corner for the different cases, just wondered what other people found.
Been having a problem with the samsung s4 galaxy though, tried different molds and cases now and i just can't get them to fit properly, grrrrrrrr
