epson 1500w
bigj2552
Re: epson 1500w
Post by bigj2552 »
does anyone use a separate/external waste tank on there 1500 ?
funkey monkey
Re: epson 1500w
Post by funkey monkey »
I have had and used and still use (The Latest being a R1500W) Epson printers from the C's, D's & R's ranges and re-set the waste tank counters on each (apart from the R1500W which I know can be re-set like the others) more than 3 times and never had one overflow and leak to have the need for a plastic takeaway box attached to the printers.
By the time you may ever need an external waste tank your print heads would have already worn out!
hope that helps.
daviddeer
Re: epson 1500w
Post by daviddeer »
I had the octoinkjet solo system on my 1400 I was amazed at how much ink it collected. A little fiddly to fit but worked without problems. Unfortunately the paper feed mechanism failed on the printer so there it sits, black, pristine and useless in my garage.
