my customers that had camo t shirts want hoodies
camo hoodies
Re: camo hoodies
Anyone know of a camo hoodie supplier ? Ive tried all the usual suspects BTC , Ralawise , Pencarrie etc but cant find any and now its getting colder all
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
Re: camo hoodies
Cheers , I found them last night but having searched them on different forums im a bit worried about quality so going to order a couple and see
IrishPrint
Re: camo hoodies
looking for the same thing, what was the quality like on these ?windyash;92257 wrote:Cheers , I found them last night but having searched them on different forums im a bit worried about quality so going to order a couple and see
Re: camo hoodies
Qualities 'OK' but not quite Gildan or Fruit of the Loom, but that is reflected in the price. Made well enough, but they tend to be a bit on the small side. Need to be washed with care, or they shrink a bit.
Earl Smith
Re: camo hoodies
Didnt know it was possible to go lower that Gildan and FOL.pw66;120496 wrote:Qualities 'OK' but not quite Gildan or Fruit of the Loom, but that is reflected in the price. Made well enough, but they tend to be a bit on the small side. Need to be washed with care, or they shrink a bit.
Re: camo hoodies
:biggrin::biggrin: I like the Gildan 50/50 as a basic go to fleece range. It is probably the only part of their range that I do like... The FotL 'Premium' range is nice, but I don't like the 'Classic' range.Earl Smith;120497 wrote:Didnt know it was possible to go lower that Gildan and FOL.
Trouble is, if you are looking for camo you are mainly stuck with 'fashion' brands which can be very hit and miss, or very expensive better quality options.
Earl Smith
Re: camo hoodies
Gildan I used once but it felt a little rough and the customer didnt like it either. So sady I didnt go back. FOL premiums are good for the price but the zip lets them down on the hoodies which are my go to item at the moment. The Heavy polo from FOL is great for the price.
My go to brand is usually Russel and Promodoro for both hoodies and Polos.
