Mug printing problems
daxus
Re: Mug printing problems
Post by daxus »
Hi i have been sublimination mugs a while now but ive been getting a lot of problems in my printing
the problem that keeps re occuring is the bottom of the mugs in the corners and sometimes acrross the centre is coming out dotty when removing the paper you can still see small amounts of ink darker then the faded image left in the areas
I have tryed changing the tempreture the pressure where i place the tape and im still getting problems as it never happens at the top of the mug i guess it might be a pressure problem and it doesnt happen on every mug but i do notice some of the mugs are different thicknesses im printing at 220 seconds and the heat press automaticly has the tempreture set i even tryed loosening the mug today cause it looked almost if i had too much pressure i know its not the inks as i have printed great mugs and usually therest of the mug is perfect i havnt placed a second piece of paper around the out side of the image i know some people do this any advice would be great :D
The darker ink you refer to sounds like it hasn't transferred off the paper. It would be worthwhile putting a straight edge across the face of the mug (from top to bottom) and see if the faded image corresponds with an indentation or bevel in the mug face
daxus
Post by daxus »
i definatley think its not coming off the paper are you meaning the mug could be more curved? i tryed it on some smaller mugs and had better results unfortunatley these were alot more expensive and it didnt entirly cure the problem
Andrew
Post by Andrew »
I would reduce the time down 160/180 secs for starters to see if that helps at all....... if you haven't already tried that. Sounds a bit like mottling that can appear from to much heat. It can happen on the lower part of the mug as the base can hold the heat. Other than that, photos would help.
daxus
Post by daxus »
Hi ive enclosed two pics of a articularly bad mug my cameras finding it hard to pick upthe detail so its not clear ihave tryed raising the image up higher this didnt help before i posted these pics i tryed a mug reducing the temp to 180 as sugested at 180 all of the base was dotty so i turned the mug around and reheated it for another 50 seconds this gave me a near pewrfect image a tiny bit blurry where i guess i had re applyed the image a little off im thinking about trying a mug 110 one way up and the 110 the other ? any advice would be great im pulling my hair out and think i have wasted so many mugs
daxus
Post by daxus »
Might help if i gave you the pics :D
Might be the camera angle, but on the mug with the missing image at the bottom - looks like it is bevelled. I would increase the pressure on the mug press so that the blanket forms a little around the top and base of the mug. You should feel some resistance when you close the clamp on the mug press to ensure it is tightly held.
Andrew
Post by Andrew »
It does look like the mug is slightly barrel shaped and the heat is not getting to that area. Where are the mugs from? Have you checked them with a straight edge?
AJLA
Post by AJLA »
I have in the past experienced major probs with a lot of waste. It does appear that your mugs are not straight, unfortunately with my press even with added pressure this did not do the trick. Putting two mugs together touching side by side you could see more than daylight through!
The only way I could use these mugs was by reducing the image size so that it does not go any where near the bottom or top edge.
Use them all up then get yourself down to BMS and get some decent ones. Never had a problem with them and i'll stick with them.
Having said that I am sure thet with thousands of mugs being produced not all can go through quality control so i'm sure many companies will occasionally be unfortunate enough to experience some quality control issues..
daxus
Post by daxus »
Thanks i hyave to say i noticed an improvement when i ordered better mugs less airbubbles marks ect and the print was alot better the problem i guess is trying to be competitive on my large orders of 100s of mugs but i guess thats why these were cheaper mugs thanks for all the advice guys :D
