White sub Tee that's not see through?
Re: White sub Tee that's not see through?
Hi All, first post so be gentle
I am surrounded by t-shirt samples, I think I have eight now and all appear see through when worn. Can anyone suggest a supplier or shirt brand I can try. Must be for sub printing by the way. Thanks in advance.
Russell HDT are great if you are happy with a vintage/slightly washed out effect. Vapor shirts are good if you want higher polyester content.
Anyone ever tried stedman active range of T-shirt? I've got a few of their cotton T's which I like so was wondering if their poly T's are any good, don't think I've ever seen stedman mentioned on here.
Hi Justin, thank, will try the Russell shirt. I have a sample of the Vapor shirts, the white is see through but the grey probably marginally better but , it's grey!
Hi Galerion, I will investigate Stedman, which supplier do you use.
http://absoluteapparel.co.uk or http://www.btcactivewear.co.uk stock them or you can also order direct from them http://www.stedman.eu/ .
