White sub Tee that's not see through?
Wisey11
Re: White sub Tee that's not see through?
Post by Wisey11 »
Hi All, first post so be gentle :wink: I am surrounded by t-shirt samples, I think I have eight now and all appear see through when worn. Can anyone suggest a supplier or shirt brand I can try. Must be for sub printing by the way. Thanks in advance.
Russell HDT are great if you are happy with a vintage/slightly washed out effect. Vapor shirts are good if you want higher polyester content.
galerion
Post by galerion »
Anyone ever tried stedman active range of T-shirt? I've got a few of their cotton T's which I like so was wondering if their poly T's are any good, don't think I've ever seen stedman mentioned on here.
Wisey11
Post by Wisey11 »
Hi Justin, thank, will try the Russell shirt. I have a sample of the Vapor shirts, the white is see through but the grey probably marginally better but , it's grey!
Wisey11
Post by Wisey11 »
Hi Galerion, I will investigate Stedman, which supplier do you use.
