What am I doing wrong?!
Anth1981
Re: What am I doing wrong?!
Post by Anth1981 »
Hi everyone I'm new on here and new to sublimation printing on mugs and like most, I'm not getting it right at all. I need help.
This is my printer
vB_ID:3776
vB_ID:3776
this is my press
vB_ID:3776
vB_ID:3776
these are the results i'm getting
vB_ID:3776
vB_ID:3776
I've read a few things on the net about why this is happening ie times, paper I'm using etc. I did use the original ink that came with the printer which are these cartridges
vB_ID:3776
vB_ID:3776
and then I installed the sublimation cartridges. Maybe the old ink is still in there and needs flushing out?
ANY help would be much appreciated. I've had the thing for a month or so now and I'm becoming very disheartened by it.
Thank you
Anth
vB_ID:3775
vB_ID:3775
vB_ID:3774
vB_ID:3774
vB_ID:3773
vB_ID:3773
A11kns
Post by A11kns »
What's your temp and times?
I used 180 deg for 180 sec. When I put a mug in the temp drops so I wait until it's back to 180 then start the timer.
Anth1981
Post by Anth1981 »
Yeah I've more or less tried every suggested time and none have worked. I either get a faint outline of the image which just rubs off or this yellowy burnt image which I've photoed there.
Martinx
Post by Martinx »
I could be wrong but judging by what's on the printer I would say you are using standard bond paper and not paper specific to sublimation.
Also do you know if the ink cartridges are sublimation based?
Anth1981
Post by Anth1981 »
Martinx;107067 wrote:I could be wrong but judging by what's on the printer I would say you are using standard bond paper and not paper specific to sublimation.
Ah no I'm using sublimation paper. I got that with the press along with the mugs
vB_ID:3777
vB_ID:3777
these are my sub inks loaded
Just need to buy sublimation ink and you good to go. This is standard ink by the look of it.
Anth1981
Post by Anth1981 »
Paul;107074 wrote:Just need to buy sublimation ink and you good to go. This is standard ink by the look of it.
vB_ID:3778
vB_ID:3778
Hers's the ink the cartridges are filled with. It is sublimation ink
jeffmr2oc
Post by jeffmr2oc »
If you has standard inks in, then as you say they may need more time to flush then out, as a noob myself I couldn't say how you tell when this has happened though, bought mine as a lot and installed the dyesub inks from the outset. I do know the initial fill takes what seems 25% of the cartridge
Sent from my Nexus 7 using Tapatalk
Quinsfan
Post by Quinsfan »
have you got an ICC profile for your inks and paper, you should get this from whoever supplied you with the printer.
Anth1981
Post by Anth1981 »
Quinsfan;107077 wrote:have you got an ICC profile for your inks and paper, you should get this from whoever supplied you with the printer.
Not that I know of. I bought the printer separately from the mug press etc.
