Resin Doming/Printers
Re: Resin Doming/Printers
Hi All,
Hopefully someone can help I am considering doming badges for outdoor use but I am unsure as to what paper/media is required and also printer please advise?
I currently have a doming kit purchased from Liquid lens which I have used but not with good results as I always seem to get bubbles and may be printing on the wrong media type Inkjet media/Photo paper.
I have attached a few images of the types of badges i would like to make.
All information welcome
Set up
Liquid lens doming kit
Inkjet CANON PRINTER IX6850I
Set up
- vB_ID:4456
- product_image.jpg (79.23 KiB) Viewed 649 times
- vB_ID:4455
- Ford-Wheel-Badges-800x533-e1451383340604-375x400.jpg (25 KiB) Viewed 649 times
- vB_ID:4454
- 750x750_1471357322Label19.jpg (76.61 KiB) Viewed 649 times
- vB_ID:4453
- domed-labels-round.jpg (92.05 KiB) Viewed 649 times
First off I would speak to Steve at Liquid Lens, he will recommend a good printer (they dont sell complete setups no more but he will advice you)
Drop the idea of using the Canon as you will find it a nightmare finding a media that will work 100% (trust me I have been there)
Use a small blow torch to get rid of bubbles, if they appear while drying then the resin/paper are reacting,
If you want to make a good go of doming then you will need to put some ££ in to it to get a setup that will work 100% and not getting customers back in a few weeks saying the resin has come away from the back or it's bubbled like hell....etc (both the resin/media need to work with chemicals that are used in washing for example)
A small setup which works good is a Roland BN-20
I was considering purchasing that exact printer but do I require it? Or can I get the same results using a inkjet printer for outdoor badges? Can you recommend any media types/ resin which I can use to achieve good results?
Liquid Lens will supply all you need other than the printer, they have been around along time and use/sell tried and tested gear so you wont fail,
I have used inkjet and laser but not got the results I wanted (tested over 12 months in all weathers)
PS: At least one of them pictures you have posted will cost you a lot of ££ if you reproduce and they come after you, DMB will vouch for that one
If you are in Birmingham try
Interfax Acuflow Ltd
2 Reddicap Heath Rd
Sutton Coldfield
B75 7DU
0121 378 2289
my friend owns it and they do a lot of doming
2 Reddicap Heath Rd
Sutton Coldfield
B75 7DU
0121 378 2289
I switched from Liquid Lens to Acuflow (see post above) and haven't looked back. It's great stuff, he offers different grades and has lots of shipping options.
Hi guys ..I ve got a sample pack from accuflo and Eddie is very helpful but i have a slight issue ..My work place is cold and I don't leave heaters on when I am not working. .so the samples I e tried did not settle even after 24 hrs ..my question is do you guys contral the room temperature for Doming ??.Do you hve to ? If so how you do it ..thanks again
