Epson 1500W install CISS fail
Ptmiff
Re: Epson 1500W install CISS fail
Post by Ptmiff »
Morning folks,
Bought brand new Epson 1500W which came with ink in the lines .. trying to install inks but can't get the row of lights to go out. Resetting the inks by pressing the white button doesn't work, I've tried that multiple times, as I've tried taking out the carts and making sure they clip in. Even switching off and on does nothing either.
Anyone else had this problem?
Any help would be gratefully received
StellaD
Post by StellaD »
Where did you buy it from?
I can't understand how there was "ink in the lines" if it was brand new as I would expect the printer, CISS system and inks all to come as separate items in a bundle which then require setting up.
Have you pressed the ink change button once, then push the white button for 5 seconds and ink change again? Sometimes need to switch printer off and on again first.
Ptmiff
Post by Ptmiff »
Yeah I've done all that .. waiting to get in touch with Inkexpress tomorrow to find out what else I can do, just thought I'd try you lovely people on here first. Will upload a pic for you to see.
Pete
Ptmiff
Post by Ptmiff »
vB_ID:5063
vB_ID:5063
Epson 1500W CISS.jpg (66.05 KiB) Viewed 666 times
This is how it came to me and after I installed it. As you can see the link lines are filled with ink.
Same as mine. It' sounds like you've done everything, re-seated carts, pressed the button. Have you tried pulling the power lead from the back (whilst printer on) leave 5 mins and switch back on?
Ptmiff
Post by Ptmiff »
Justin;130539 wrote:Same as mine. It' sounds like you've done everything, re-seated carts, pressed the button. Have you tried pulling the power lead from the back (whilst printer on) leave 5 mins and switch back on?
Will give that a go .. thanks '' no difference'' sadly
loobyloo
Post by loobyloo »
you haven't pressed the carts in enough - I had exactly the same problem with my new one about 2 weeks ago. I was scared of breaking it. I phoned the supplier and they told me to give it a firm push using two hands. It is quite a loud click when in properly and then the lights go out and the printer starts charging.
Ptmiff
Post by Ptmiff »
loobyloo;130541 wrote:you haven't pressed the carts in enough - I had exactly the same problem with my new one about 2 weeks ago. I was scared of breaking it. I phoned the supplier and they told me to give it a firm push using two hands. It is quite a loud click when in properly and then the lights go out and the printer starts charging.
We have a winner, quite ashamed to say that this burly 6'4'' bloke hadn't done exactly that. Sorted now .. thank you so much :redface:
Hahaha, frightened you'd push them through the bottom eh? lol. We thought you'd tried that! :-)
Good that you have it sorted.
