Epson 1500W install CISS fail
Re: Epson 1500W install CISS fail
So the CIS was supplied with the inks in?
loobyloo
Post by loobyloo »
Your welcome Ptmiff - now if only someone would give me advice on which press to buy LOL
Ptmiff
Post by Ptmiff »
Justin;130546 wrote:So the CIS was supplied with the inks in?
Yeah it arrived just as the pic .. all I had to do (or didn't as was the case) was clip the carts in after assembling the bar across the top.
InkExpress
Post by InkExpress »
Hi Ptmiff, that is one of our ink system setups. If the red LED lights are not going out the cartridges are not seated correctly. Its a common thing with that CISS and model., The cartridges are very tight and need to be pressed down very firmly, they will click and lock into position. Once installed fully press the ink drop button on the front panel of the printer. It should then charge the inks.
Alex
InkExpress
loobyloo;130541 wrote:you haven't pressed the carts in enough - I had exactly the same problem with my new one about 2 weeks ago. I was scared of breaking it. I phoned the supplier and they told me to give it a firm push using two hands. It is quite a loud click when in properly and then the lights go out and the printer starts charging.
Ah beat me to it Louise!
Alex
Ptmiff
Post by Ptmiff »
InkExpress;130556 wrote:Hi Ptmiff, that is one of our ink system setups. If the red LED lights are not going out the cartridges are not seated correctly. Its a common thing with that CISS and model., The cartridges are very tight and need to be pressed down very firmly, they will click and lock into position. Once installed fully press the ink drop button on the front panel of the printer. It should then charge the inks.
Alex
Hey .. yes it is your system, bought from eBay, with next day delivery to Aberdeen. Very impressive!!
I was scared to 'push' to hard .. but got there in the end with Louise's help. :wink:
InkExpress
Ptmiff;130558 wrote:Hey .. yes it is your system, bought from eBay, with next day delivery to Aberdeen. Very impressive!!
Ah you are not the first to be scared by pressing the cartridges in. Ideally we would have cartridges that were looser fit, but I used to get issues with the chips being lose so opted for tighter cartridges. Once in they don't really ever need to come back out.
If you get any issues please don't hesitate to contact me through eBay, here or directly and I will do my best to help.
Good to hear it arrived in good time too, we try to ship everything same day (we do put longer shipping times on eBay to make sure we don't miss the deadlines set by eBay)
Alex
